DaddyMan
Oct 15, 2018Aspirant
Want to use Orbi RBK53 as primary router and mesh with Airport Extreme as extender
I am replacing my Apple Airport Extreme Base station router with Orbi RBK53 and want to re-purpose my Airport Extreme (AE) as an extender/beacon (in bridge mode) but without using any ethernet cables...
Oct 15, 2018Guru - Experienced User
You can use AE in wireless bridge mode if it supports it. It should connect to the 5ghz radio on the orbi as a connected client.
You'll have to try this out and see. You'll need to refer to Apples support site and information on configuration of the AE...
- AC641Oct 15, 2018Luminary
Is using a couple of Powerline Adapters an option to give you the Ethernet connection?
- DaddyManOct 17, 2018Aspirant
I would still have the issue of running cables from the adapter to the Airport Extreme (AE) Basestation as extender/bridge. It's an impractical option but slightly better than running Ethernet cables end-to-end through walls & floors...
FURRYe38 - will have to try that - so far it seems experimentation is the way to go forward - will be an undertaking and sharing on this forum - any thoughts on how do I ensure testing if the AE is functioning as desired?
- ekhalilOct 17, 2018Master
DaddyMan wrote:
will have to try that - so far it seems experimentation is the way to go forward - will be an undertaking and sharing on this forum - any thoughts on how do I ensure testing if the AE is functioning as desired?I tried to connect my Airport Time Capsule wirelessly to Orbi but that did not work for me! I did not get the option "Extend Cusrrent Network" that you usually get if the network is from another Airport router.
- FURRYe38Oct 17, 2018Guru - Experienced User
Not sure if the AE will be compatbile in wireless bridge mode, so you can try the following:
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.Also try this as well:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
v210 Daisy chain fixed:
https://community.netgear.com/t5/Orbi/Orbi-doesn-t-work-with-Chromecast-Please-help/m-p/1652882/highlight/true#M43708You should have a satellite in place of where there AE would be needed...Are you just using the AE as additional support for connections?
