TrickyRic's avatar
TrickyRic
warning do not buy ORBI exterior melting
WARNING DO NOT PURCHASE RBK50/ AC3000
NETGEAR WILL NOT REPLACE THESE FAULTY UNITS
THE EXTERIOR OF THE UNIT IS FAULTY AND DETERIORATES IN HUMID CLIMATES AND BECOME STICKY IT CAN NOT BE CLEANED
$650.00 WHAT A WAIST OF MONEY
  • Retired_Member's avatar
    Retired_Member
    Yeah, it's a royal pain in the ***. Mine have been sticky roughly since a year after I bought the RBK50 combo some three years ago. Nothing much I can do about it too. Luckily they're both out of sight so I don't notice it much and they function just fine, but for the amount of money you spend it definitly should be better.
      • TrickyRic's avatar
        TrickyRic
        Well Mikey I'm guessing you work for Netgear.
        You don't know what your talking and neither does the fool in the video.
        You just googled it I suspect.
        Its common knoweledge that alcahol actually breaks down plastic neoprene and rubber.
        Unless the Orbi is made of some new material a Netgear material scientist dreamt up.?
        Alcohol it not a fix it but will make the deterioration worse.
