knewbee
Oct 05, 2018Aspirant
Weak Signal to Satellite Right Next to Router!
I just purchased the RBK50 router and satellite kit and set it up according to instructions. I'm getting a signal ok to my laptop 10 feet away, speedtest showing 155mbps download and 11.8 upload.
So why is the satellite LED showing amber when it's right next to the router, instead of blue?
- Retired_Member
How long has it been amber? Once things settle down, ALL lights should go out. After about 30 minutes if the lights are still on I would re-boot all.
- knewbeeAspirant
The LED light shut off, so I moved the satellite downstairs and about 10 feet or less from where I was sitting with my laptop and it took awhile, but it's showing blue and I'm getting 188mbps on my laptop about 6 feetl away from that, so I guess it all good to go.
Thanks a lot!
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Any Wifi Neighbors near by? If so, how many
