bryanyu81
Jul 29, 2018Aspirant
What is the highest speed that the Orbi's can handle?
Good Day All!
I have the Orbi Mesh Router. The Orbi AC2200 and I have the main router in the living room and a Satelite down in the basement. I have Verizon Fios package that's supposed to give...
Aug 01, 2018Guru - Experienced User
Which RBR or RBK do you have? 40 or 50?
What FW is currently loaded?
What is the Mfr and model# of the IP modem/ONT the Orbi is connected too?
What is the speed test results with a wired PC and a browser connected to speedtest.net? Wired speedtesting is preferred as wireless can't perform the same as wired.
Did you set up the router and enable QoS speed test, traffic meter or access controls? If yes to any of these, you may need to do a factory erase on the router and set up from scratch, this time, do not enable the QoS speed test, traffic meter or access controls. User mentioned that these will slow the speed down on a 1Gb ISP service...
