bryanyu81
Jul 29, 2018Aspirant
What is the highest speed that the Orbi's can handle?
Good Day All!
I have the Orbi Mesh Router. The Orbi AC2200 and I have the main router in the living room and a Satelite down in the basement. I have Verizon Fios package that's supposed to give...
st_shaw
Aug 03, 2018Master
I haven't seen any reports of more than about 550 Mbps WiFi throughput on Orbi.
I'll test mine this weekend with the latest MacBook Pro.
st_shaw
Aug 04, 2018Master
I tested Orbi WiFi throughput with the latest 2018 MacBook Pro. I used iperf3 to measure throughput to a wired server on the LAN side of the Orbi. Tests ran for 30 seconds and transferred ~2 GBytes of data. Orbi is in access point mode. The Macbook had clear line of sight to the Orbi AP and had full 866 Mbps link speed.
When connected to the the satellite via WiFi, the measured throughput was 560 Mbps. Pretty impressive.
When connected to the Orbi router via WiFi, the measured throughput was 630 Mbps. Very impressive.
I expect the satellite figues are lower because the data went across the Orbi wireless backhaul. The satellite and router are in different rooms, with a couple walls between them, so the backhaul was the limiting factor.
