rampi's avatar
rampi
Guide
Jun 10, 2020
Which satellite models are compatible with RBR50
I have RBK50 system (RBR50 router and RBS50 satellite).
I am thinking of getting another satellite(s) to extend/improve the coverage.
Question is which all satellite models are compatible with RBR50 ?
Specifically can I get the small RBK12 and use both those devices as satellites to my main RBR 50 ?
  • rampi wrote:
    Was reading up a bit ... I guess my only options are RBS20 & RBS50?
    No, any of the options I listed will work. I was just saying the rbs50 and rbs50y both have the 4x4 1733mbps backhaul. The rbs20, rbw30, rbs40, rbs40v all use the 866mbps backhaul. They still work fine and in many cases with a very similar performance.
  • plemans's avatar
    I wouldn't use the rbs10's.
    I'd recommend these:
    rbs20
    rbw30
    rbs40
    rbs40v
    rbs50
    rbs50y
    reason why is they're all triband. The rbs10's are dual band.
    something else to keep in mind is the rbs50 and rbs50y are the only 2 that keep the full 1733mbps backhaul of the rbk50 series you're on. the others use 866mbps.
  • Was reading up a bit ... I guess my only options are RBS20 & RBS50?
    • plemans's avatar
      • rampi's avatar
        rampi
        Guide
        Thanks. Just wanted to update that I went with RBS20, with wired backhaul.
