Mitchw18
Dec 10, 2016Aspirant
Which SSID do I connect to on my ORBI
Hello, I've successfully setup my ORBI and so far am very pleased. I successfully changed the SSID to my current SSID and now I have two identically named SSIDs. Both work when I connect to the...
wanderoldies
Dec 13, 2016Aspirant
If you have the Satellite too close to your Router you will see two with the same SSID because the Satellite uses the same SSID as the Router. Try moving the Satellite a lot further away from your Router and then you should see only one SSID to log in to. If you log in near your Router, then if you move closer to the Satellite it will automatically switch over to the Satellite without you ever noticing a thing. It would be seemless. Hope this helps.
