Mitchw18
Dec 10, 2016Aspirant
Which SSID do I connect to on my ORBI
Hello, I've successfully setup my ORBI and so far am very pleased. I successfully changed the SSID to my current SSID and now I have two identically named SSIDs. Both work when I connect to the...
Mitchw18
I do have another wireless router, but it uses a different SSID. I named the ORBI guest SSID differently as well. It's very odd that I'm seeing two identical named SSIDs and they both work using the same password that I assigned. I'm going to re-install and see if that clears it up. Thank you for the response, Mark.
st_shaw
Jan 17, 2017Master
You said, "It's very odd that I'm seeing two identical named SSIDs and they both work using the same password that I assigned. "
Well, that's how the system is supposed to work! You enter the single SSID and password on your mobile device, then your mobile device connects to the the best signal (either 2.4G or 5G) on either the router or the satellite as you move around, depending upon where you are located relative to the Orbi components. If you are close you get 5G. If you move far away you get 2.4G.
