Mike734
Aug 06, 2017Star
Why does the firmware status say, "update failed" for my RBS50?
When checking the firmware version of my router, two satilite system the router says it has 1.12.0.18 nstalled but the satilites say update failed. Both seem to be working but with less range than before. When I check to do a manual update, it says that the latest update is already installed.
access the actual ip address for the sat's and open it and see what fw it says is installed on the sat's them selves
- I KNOW what version is installed. I want to know why it says, Update Failed.
Mike734 wrote:
I KNOW what version is installed. I want to know why it says, Update Failed.then if you KNOW what the fw version is reporting on the sat's themselves and not just what is reported in the router gui then dont worry about it , its obviously just a reporting error
