HannoosH's avatar
HannoosH
WIFI 6 with RBK50
Will the current HW of RBK50 supports the Wifi-6 update that will happen end of the year, or there will be a new HW?
  • schumaku's avatar
    schumaku
    No way, much to different and much more enhanced technology and chipsets required for both the 2.4 and 5 GHz bands.
    If we are lucky we might see WPA-3.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi HannoosH
    It will be a different hardware. It is expected to be available in the second half of 2019.
    Blanca
    Community Team
    • michaelkenward's avatar
      michaelkenward
      Blanca_O wrote:
      Hi HannoosH
      And it might be wise to wait a bit, for bugs to be squished, before shelling out any cash.
      • schumaku's avatar
        schumaku
        And it's worth checking the fine print - both Wi-Fi 6 platforms Netgear has deployed on the RAX80 (AX8) and the RAX120 (AX12) currently don't fully comply with the formal specs as of writing.
  • Hello,
    What is the release data for WIFI6 with RBK50 ?
    Thanks,
    Hari
    • schumaku's avatar
      schumaku
      Hi Hari,
      No Wi-Fi 6 on the RBK50 - new hardware generation is required.
      • harisadhu's avatar
        harisadhu
        I am actually planning to buy a most latest and greatest Orbi's mesh wifi Router. What do you recommend ?
        Thanks,
        Hari
  • FURRYe38's avatar
    Will probably be late this year or staring of next.
    • schumaku's avatar
      schumaku
      Expect to see the Wi-Fi 6 Orbi on closed Beta these days, unless some show stoppers show up it should not be much more than a few weeks.
