JamieC
Jul 06, 2020Aspirant
Wifi Certificate error
I have had my Orbi for over 6 months without too many issues, then today I started getting a 'Connection not private' certificate error. I have checked the timezone, all good, updated the firmware and can't seem to find what is causing the issue. Need some help before I completely loose my mind!
Is this when you connect your wifi device to the Orbi or is this on your wifi device connecting to a web site?
What device are you using?
- JamieCAspirantIt’s when I connect a WiFi device to a website, they join the Wireless network without issue Happens to all the WiFi connected devices, which is somewhat frustrating!! Wired works fine, it’s just affecting WiFi devices.
What web sites are you visiting if we may ask you.
I presume you have WPA2 and AES enabled on the RBR?
