Kevberry
Dec 28, 2021Aspirant
WiFi network without cellular AX4/AX1800
Hi, Will this router operate the WiFi network without a sim card or when out of cellular service? I want to be able to link devices on the wifi network and dont always have cell coverage. This is an LAX 20 model.
thanks for any help you can provide.
Re: Nighthawk® AX4 4G LTE Modem + WiFi 6 Router WiFi network. SN 6BG2197EA024A
You might have better luck with the forum for that specific device where there might be users that have that model.
I'll notify a mod to move the post but it can take a bit.
- KevberryAspirant
Thanks for your reply, no other suggestions so far.
Yes it should since it does have a WAN port in back that you can connect to a ONT, Cable or DSL modem:
https://www.netgear.com/images/datasheet/networking/wifirouter/LAX20.pdf
