Zuhair2008
Dec 05, 2018Tutor
Wifi Off every 5 mins !!
Hello
I just bought RBK53, WiFi signal is turning OFF and ON every 1-5 sometime every 45 minutes and I don't no what's the solution.
Firmware Version V2.2.1.210
Do a factory reset on the system and setup from scratch. If it still continues,
Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
Zuhair2008 wrote:
Hello
Nothing changed ..
Zuhair2008 wrote:
Hello
- ekhalilMaster
Zuhair2008 wrote:
Hello
..What wired devices do you have connected to Orbi? Any mesh speakers (e.g. Sonos)?
My connection is Fibre .. I'm using Huawei EchoLife HG8245Q , there are two devices connected to it
Wired :
1- Huawei EchoLife HG8245Q --> RBR50 .
2- Huawei EchoLife HG8245Q --> TP-Link Powerline 1 --> connected to TP-Link Powerline 2
nothing wired connected to RBR50
ekhalil wrote:
Zuhair2008 wrote:
Hello
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Wired :
