zdbrad
Mar 30, 2020Aspirant
Will there be any issues connecting an RBK10 Satellite to an RBK50 router?
We've set up an RBK13 system, but it we cannot get a good signal to either of the Satellites from the Routers. It works OK if daisy chained, but its still only a 'fair' signal. We are very limited with the satellite locations. I'm thinking of getting an RBK50... does anyone know if I can connect the RBR10 Satellites to the RBK50 Router? I believe the RBK50 is strong enough to get a better signal to each of the satellites, but just need to be sure the RBR10 satellites (from the RBK13 pkg) will connect to the RBK50 router.
Thanks!
Possible, thoght I haven't seen anyone post anything similar. Check the specs on each systems. The 1 series RBS may not have the same specs or connection ratings.
Satellites work with whatever Orbi base station you throw them at. Some are more capable on the wifi front.
- zdbradAspirant
Thanks for the info. I checked and the RBK50 is tri-band, where the rbr10 is dual band. I'm not sure if this indicates there may be issues, but it looks like I'll be giving it a try.
Thanks again for the help.
Let us know if it works. Dual band means that there will be no wireless back haul with the 1 series RBS. The 3rd radio on the 50 series is what this is used for.
