heathweather
Aug 22, 2019Guide
Wired backhaul configured but still shows WLAN Backhaul Statistics
I've got an RBR-50 (configured as an AP) with satellites configured using wired ethernet backhaul. The GUI shows all the satellites connected using wired backhaul.
When I go to advanced -> administration -> router stats , there's still a significant amount of traffic being reported over the WLAN backhaul ?
With everything being configured as wired for the backhaul, these numbers should not be incrementing?
- interestedpersoAspirantI would advise to untick 'enable daisychain topology " it should not be getting used when connected via ethernet but it is and it has a negative affect on wiresless speed i have found.
The "enable daisychain topology" is not ticked. That was a lesson learned in getting the ethernet backhaul to work. Thank you for the reply.
Are RBS directly connected to the RBR or thru a LAN switch?What is the Mfr and model# of the ethernet switch if one is in the configuration.
Let us know if disabling Daisy Chain does anything differently for you.
heathweather wrote:I've got an RBR-50 (configured as an AP) with satellites configured using wired ethernet backhaul. The GUI shows all the satellites connected using wired backhaul.
Firmware: 2.3.5.30
Both RBS connected through tplink TL-SG1024DE ( it is a managed switch, I've got IGMP snooping disabled )
I do not have daisychain enabled.
Thanks for your reply.
What is the status if you connect one of the RBS or both as a quick test directly to the RBR with out the switch in the middle?
One other factor of the switch that may be a cause, your switch seems to have Green Ethernet features: "Innovative energy-efficient technology reduces power output by up to 18%" Something that also causes Orbi to not work well. :smileyfrustrated:
- ekhalilMaster
heathweather wrote:......
Were the Satellites synced using wireless backhaul before the Ethernet wiring is done between the nodes? If yes then I believe that's why you see the two-way communication between Router and Satellites. I believe that this is what is causing the IP loops and wifi disturbances in the latest software releases.
The following procedure should always be followed when using wired backhaul.
- Switch off the Satellite
- Go to Attached Devices in the web GUI and click on the "Disconnect" button beside the Satellite in questions
- Turn on the Satellite and use a paper clip to factory reset the Satellite
- When the Satellite is up after factory reset, press the Sync button on the Satellite (while the Ethernet cable to the Router is connected) and then on the Router
- When the Satellite is added it should behave correctly.
