shadowsports
Oct 15, 2017Hero
Wireless Performance Mixing AC3000 / AC2200
Current system: RBK50 (claims up to 5,000sq ft) coverage. FW v1.12.0.18 Home: 2 story 2,600sq ft, nothing significant from a construction or interference stand point. RBR50 on first floor left si...
- Jan 27, 2018
wrote:Is this a case of the rbk/s 50 have a 2x2 setup vs a 3x3 or whatever the r7000 and r6400 provides to the client devices?
i too am curious what effects mixing satellite types does to the back haul.
Glad you brought this up.
I've attempted to do extensive research. These are not Meraki's, Rukus, etc, enterprise grade devices. They are consumer grade, and if they supported AP "isolation" (lack of better word) then Netgear would have said "hey, each unit performs independantly". But they didn't. Because they can't.
Further, With the latest FW, you can change the operate mode from STAR to Daisy Chain... I can tell you right now that if one of the satellites is relying on a "slower" device in the chain for front/backhaul performance it's not going to run faster than the device is connecting to. This is confirmation to me that introducing a "slower" upstream device is absolutely going to affect downstream (down the chain) device performance. So there is no way I'm going to intruduce a slower device to save a buck. It totally dillutes the purpose of buying the higher priced AC3000 system.
Cheers
Shotround
Jan 21, 2018Apprentice
shadowsports
Jan 27, 2018Hero
Cheers
