nedlinin
Jul 27, 2021Tutor
Woke up and router inaccessible - Can't factory reset
Went to bed last night to a nice stable internet connection.
Woke up this morning to everything disconnected. Go to login to the Orbi to reset it and the app won't connect. Log into my desktop and open the browser and hit the webpage address only to get Connection Refused.
So I walk over to the router and satellite and power cycle them both. They come back and.. no connection. So I attempt the factory reset procedures detailed on the site (holding reset button with a paperclip for at least 7 seconds). I'll note that this documentation states CLEARLY that things like SSID will be wiped.
I wait a few minutes and.. well it boots back up but all my settings are still there apparently as my SSID is still customized.
So I dig further. I try the tftp method of applying a firmware over the top of a broken one. The router takes it and it boots up. Same settings and same symptoms. So I try again, rolling it back a few firmware versions to one I know I had been running for 6+ months with no issues. Same problems with connectivity.
How the hell do you *actually* factory reset this stupid thing?
Try this?
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
https://www.thewindowsclub.com/enable-tftp-windows-10
https://www.youtube.com/watch?v=R9DLrLQrpaw
Try nmrpflash?
I've had luck with that when tftp didn't work
https://github.com/jclehner/nmrpflashIf this fails you'll need to contact NG support.
Pressing the reset button in back for 15 seconds and release should do it. Be sure you feel the momentary bump when you press the button. Hold it for 15 seconds then release. Wire connect 1 PC to the RBR and try to access 192.168.1.1
- nedlininTutor
It does not work.
I've tried iterations of 7 seconds, 15 seconds, 30 seconds, 60 seconds and 90 seconds. None actually factory reset this device. As soon as it boots it still has my old SSID, DHCP disabled, etc. The page at 192.168.1.1 is inaccessible giving connection refused.
Try this?
Try nmrpflash?
