Aerofan81's avatar
Feb 13, 2023
Work VPN Being Throttled
Currently Using Netgear Orbi RBR50v2, Firmware V2.7.4.24 on a home network.  I use a VPN for work and when I'm directly connected to my modem, I'm able to pull 170+ on the download when connected to the VPN, but when I'm connected to my Orbi system, both wireless and hard wired, I'm only able to pull 30+ on the download.  Anyone know why the Orbi is throttling my VPN connection?
  • Aerofan81's avatar
    Aerofan81
    Feb 14, 2023
    Big-IP Edge Client is my VPN, but I don't think that is what is throttling my connection.  When I connect direct to my modem (ethernet connection) and use my VPN, I get over 150MB/s down.  When I'm on the Orbi, I'm getting 8.86 down and 8.86 up.
  • michaelkenward's avatar
    michaelkenward
    Which VPN? Maybe that is throttling your connection.
    Anything that forces your router to work hard on signal processing – parental controls, QoS and maybe VPN – can slow things down.
      Aerofan81
      Star
