Br4den
Feb 08, 2025Follower
Xbox party chat not working “your network settings are blocking party chat. [0x89240011]”
Whenever I try to join/invite people to an Xbox party it disconnects me displaying “your network settings are blocking party chat. [0x89240011]” my NAT type is open and UPnP is on. I’m not sure what else I can do.
Any help is appreciated.
- barbarajohnsongAspirant
I had a similar Xbox party chat issue, and even with Open NAT and UPnP enabled, it can still happen because of privacy settings, Teredo connection problems, or router/firewall filtering. Try going to Xbox Settings → Account → Privacy & online safety and make sure communication is allowed, then run Settings → General → Network settings → Test NAT type and Test multiplayer connection. Restarting the router and clearing the Alternate MAC Address can also help. If party chat still fails, you can at least use other ways to connect with people while troubleshooting, like Chat with random people, but the Xbox error itself is usually caused by network or account communication settings rather than NAT type alone.
Br4den wrote:
Whenever I try to join/invite people to an Xbox party it disconnects me displaying “your network settings are blocking party chat. [0x89240011]” my NAT type is open and UPnP is on. I’m not sure what else I can do.One requirement for allowing connections from the internet to a device on the local network is that the router that has the public IP address must accept those connections and pass them through. It is very common for internet subscribers to have a device from the Internet Service Provider that is a combination modem/router/(and even WiFi) device. When they connect their own Orbi WiFi system to the ISP device, there are now "two routers". (This is often called a "Double NAT" situation.)
There are many ways to check for this. One is to compare the IP address that shows up in one of the "What is my IP?" web sites, such as https://whatismyipaddress.com with the IP address that appears on the Orbi router information page, either:
- On the Orbi 'app on the "Router Settings", "Internet Settings" panel, or
- On the Orbi web interface, Advanced Tab home page, on the "Internet Port"
If these IP addresses are the same, then the Orbi router is connected directly to the internet. If they are different, then this is definitely a "Double NAT".
Something to contact MS support about.
One sign they are getting a public IP address is the presence of the status of OPEN NAT seen on the game console. Anything else would be Moderate Or Strict NAT that would be a cause from not getting a public IP address or having a router upstream from another router.
Thanks. (Still not getting a Game Console - of any brand.)
Looks like the Microsoft forum had a post last August on this specific topic:
