PoorOldRudy's avatar
PoorOldRudy
Xfinity gigabit plan but Orbi maxes out around low 500Mbps
Just ditched the new Xfinity modem (the black technicolor one that looks like some kind of award/trophy) for an Arris SB8200. Before the Arris, my Orbi was consistently getting 400-450Mbps on the Orbi app speedtest. Hooked up the new Arris modem, and now I am getting a little bit better but nothing near what I'm getting when I plug a laptop straight into the modem. Now my speeds are in the low 500Mbps on the Orbi app speedtest. But 700-800Mbps on my laptops I tested. I did factory reset the Orbi router and satellites after I got the new modem setup. My Orbi system has the 2.3.5.26 FW installed. Just to be clear, I'm talking about my speeds from the modem to the Orbi Router.
I know I'm being nit-picky and already have great speeds. But I'm curious as to why the Orbi router isn't showing anything near the 700-800Mbps I'm seeing on my laptops? I have read several posts here and on other sights where people seem to think the Orbi can't handle gigabit speeds. Is this correct? I never saw a definitive answer.
  • Retired_Member's avatar
    Retired_Member
    was this modem a modem/router combo????
    • PoorOldRudy's avatar
      PoorOldRudy
      Yes, the one I sent back to Xfinity was the Modem/Wifi Router combo.
  • plemans's avatar
    I've got an Orbi and can confirm it should work. I can regularly pull 940 mbps down on it through a CM1000.
    did you try resetting after updating firmware and changing modems? Anytime you change modems, its a good idea to start fresh.
    Are you using QoS?
      PoorOldRudy
      Yes I factory reset the Orbi router and satellites after I got the new Arris modem up and running. On my Orbi admin I don’t have a QoS setting. But I don’t have or see any setting like that. I’ve heard some people mention that traffic meter is similar but I do not have that enabled either.
      • plemans's avatar
        I'd start with replacing cables and trying a different device to see if that impacts it at all.
        Are you hardwiring into a satellite or the main router?
  • Here is a screenshot of my Speedtest history. I got the new modem setup on the 18th. And now that I look at it my speeds haven’t gone up that much. You’ll notice prior to the 18th the up and down are swapped. I’m assuming because of the recent Orbi app update. My upload speeds have been rock solid.
      PoorOldRudy
      I'm not a hardware guy, but could it simply be the limitation of the Orbi hardware? As a router it can handle the gigabit speeds but when you run code on it to test bandwidth it just doesn't measure up?
      • FURRYe38's avatar
        Yes, it could be. We don't know for sure if the RBR20 series supports 1Gb WAN to LAN. Seen others with similar problems with the 20 series Orbi. Though I think the 50 series supports 1Gb WAN to LAN, i've not been able to get my RBR50 to test out much past 400Mbs for some reason. Others are reporting getting near 900Mbps, while others are not. I presume there is a FW issue also as a factor. Hardware Acceleration or Cut-Through features are needed for any home class router to see anything near 900Mbps. I have a XR450 and a couple of other non NG routers that test out to 900Mbps, So far my RBR50 and a XR700 I tested fails in this area for some reason.
        Blanca_O
        No, the modem only a modem so changing to AP mode on the RBR won't work unless you have a different router that you can place in the middle. I did notice that putting the RBR in AP mode, this mode see's 900Mbps. Of course it should as the WAN to LAN changes to LAN to LAN and all connections are 1000Mbps and speeds are near 900Mbps when testing.
      PoorOldRudy
      FURRYe38 I've seen people recommend/suggest switching to AP Mode. Do you think this could help in my situation? Can the Arris SB8200 function as a router?
  • FURRYe38 Saw several of your posts recommending users to hardwire straight into the Orbi and do a speedtest through the app and not the site. I did get a couple test results in the 600-700Mbps range. But most landed in the 400-500Mbps range. So the speed is there, almost, but something is getting in the way. I know it's cable which can degrade when other people around you are using it. Which could be part of it. I had a tech who came out to test my equipment tell me we are on a shared line with 20 other people. So... there is that.
    While on the Orbi's wifi I have tried several speed tests on the http://www.dslreports.com/speedtest which have came back in the 500+Mbps range. Has anyone ever tried the dslreports speed test?
    • FURRYe38's avatar
      Ya seems like something in the RBRs FW and or HW is not fully getting or allowing near 900Mbps...
      Ya, used dslreports.com before as well. The test I run is more local and has no internet processing interferences.
