robatl's avatar
robatl
Star
Sep 06, 2021
> Remote Management
 Nighthawk LAX20   Firmware Version V1.1.6.28_2.0.49
Remote management missing from the router configuration. Is this not a feature?
  • robatl's avatar
    robatl
    Sep 07, 2021
    The Anywhere access in the app is only for allowing the app to access the router from anywhere. That does not enable the router to accecpt http nor https requests.
  • michaelkenward's avatar
    michaelkenward
    The manual says it should be there.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Set up remote management.
    You may have done that already. I can't tell from your message.
    I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
    PS I assume you mean the LAX20 and not the RAX40 in your footer. Very different animals.
    • robatl's avatar
      robatl
      Star
      Verified the manual, I did not see release notes the feature was being removed. Should it be there and how do we notify netgear? I have opened a ticket on this twice...
