  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi edub4206,
    Thanks for the good question. I will forward your question to my internal team and see what they say. :]
    As for now the LB112X family is compatible with:
    LB1120-100NAS:
        LTE: Bands 2, 4, 5, and 12
        3G: Bands 2 and 5
        2G: Not supported
    LB1121-100NAS:
        3G: Bands 2 and 5
        2G: Not supported
    Please refer to the link below for the information location.
    https://www.netgear.com/images/pdf/LB112X-User-Manual.pdf
    - Jason N
  • i highly dought it will be able if the modem it self does not support LTE Band 71. Netgear will have to make a new model that does.. i wish they would make one that supports LTE Bands 2 4 5 12 66 and 71 with Carrier Aggragation and the ability to select which LTE bands you want to use withen the modems GUI plus the Ethernet Output thats found on the LB112x
    • edub4206's avatar
      edub4206
      Audiorulz4u, I agree with all your wish lists items, but I am hoping since I am using an external antenna that it is just a firmware update to recieve the 600 mhz band.
