Marlee222's avatar
Marlee222
Follower
Feb 25, 2019
Admin password
I've just purchased the Nighthawk M1 MR1100 mobile router.  trying to log into the admin page but the default passwork is not working.  I've tried admin & password but nothing is working.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Marlee222
    If it is not accepting the admin password then the next step is to factory reset the unit.
    Blanca
    Community Team
    • dentsup's avatar
      dentsup
      I have the same problem; I cannot log into the router. I am using Genie 2.4.60. Using default of ádmin' and 'password'. Tells me the password is incorrect. I have done a hard reset (pressed the reset button) three times. M1 registers it is doing a factory reset but I still cannot log in.
      • Blanca_O's avatar
        Blanca_O
        Hi dentsup
        May we please know the exact model of your M1 Nighthawk router? You can also check M1 settings vis Web GUI. Here's how:
        - Open a web browser
        - Enter http://192.168.1.1
        - Enter the administrator login password.
        *** The password is case-sensitive.
        Please let us know of the result.
        Blanca
        Community Team
  • Ive been having a tough time trying to find a password for the admin login and finally found out that since I had a ATT-WIFI-Mobile Router the admin password was attadmin. I called connected with att support on the web site and tried for around an hour to get them to help reset it or send a code or something but didnt help. The next day I asked someone on Ebay who were selling them and they let told me if it was an att then the password was attadmin.
    Who would have ever thought they would do something like that huh? Hope this helps someone because I had almost decided to give up. That should be on the Box or the insert.
