yobyotan
Jan 29, 2020Aspirant
After ATT update to NTG9X50C_12.05.05.12 cannot connect to LTE network
Since the update to the latest ATT firmware, my unit has issues connecting to the LTE network. I have to restart it several times before it will connect. I usually use it tethered via USB-C but connecting to it via WiFi also doesn't work.
Clearly, it's the MR1100 since if I restart it enough times, it will connect.
Is there any way to fall back to the prior firmware level which worked fine for me?
