LgModem's avatar
LgModem
Novice
Feb 25, 2015
Aircard 320U Unsolicited Response -Enable
Hi,
I have connected to /dev/ttyUSB2 (AT port) of AirCard 320U in Linux through minicom .
But not getting Unsolicited responses like RSSI etc .
Is there any specific AT command to enable Unsolicited responses like signal strength etc .
( Note: Huawei dongle is giving response properly ) :confused:
  • Yes AT+CSQ will give one time response when we send that command.
    But i want to enable Unsolicit response (Like ^RSSI signal strength which comes automatically time to time in Huawei)
  • Hi LgModem,
    I have also seen how the Huawei USB modems automatically display signal strength info but the NETGEAR modems do not have such a feature to enable. You can try using at!gstatus in a script to obtain the signal strength periodically.
    Kind Regards,
    Arodi
