Hormelo
Nov 30, 2015Follower
Aircard 762s does not work with VPN via USB
Hi,
I have following problem:
When I create VPN connection my internet stops working after the connection to the VPN serves is established (all traffic dies).
The problem is only present when I connect to the Aircard 762S via USB cable. If I deactivate the direct IP connection via USB and connect to the Aircard via Wi-Fi the VPN connection works.
So the VPN in my mac environment requires certain TCP ports. Do I Have to set any specific port forwarding to the Aircard setting to make the connection work through USB cable? VPN traffic passtrough and all the other 'easy' solution are enabled.
I am running MAC OS X El Capitan.
Thanks you in advance for any suggestions what to try!
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Hormelo
We recently released new drivers for EL capitan so go check the page for your carriers 762s.
DarrenM
