Goodwill_Hobo
Oct 18, 2015Follower
AirCard 763 - DNS Manual Settings
Problem:
I cannot reconnect after setting up OpenDNS on my AirCard 763S.
What I did:
I connected to the AirCard device through my computer and selected DNS Mode - Manual instead of Auto. It then offered me two IP address fields for changes in Manual mode. I put in the two OpenDNS IP addresses. I then accepted the changes to save them in the device which caused the AirCard to reset. I noticed that the internet connection went down as expected and the it came back ON again. No problem there. So now the DNS filtering works fine as well. I test the DNS operation using sites i had filtered out to confirm operation. However, as a result of these changes, I can no longer connect to my AirCard to manage my settings now.
Resolve:
What must I do to restore an administartor connection to my AirCard to manage settings using my computer in the future?
Thanks, Dave
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello Dave
Have you made sure the default gateway Ip hasnt changed you can check that with ip config /all in your command prompt or you can use these links based on your provider.
DarrenM
