EAGLW
Jul 05, 2016Initiate
Aircard 763S MEP Unlock tool for Windows 10
I want to unlock my Aircard 763S but I am having issues downloading and running Aircard Watcher. I have downloaded and started the exe file from http://downloadcenter.netgear.com/en/#searchResults but it will not run on my Windows 10 OS. I can not find that the program has been loaded and installed either. Is there a more up-to-date download file that I should use?
Need some help on this as I am stuck. Also, does anyone have the unlock MEP code for the Roger's version of this?
Thanks a lot.
Erik
- simonsays739Aspirant
also need help with this issue AC-782s
