GILLIAN
Jan 26, 2016Follower
Aircard 763S MEP Unlock tool
Help! Trying to unlock the aircard (763S) but the link provided by Fido (service provider) is to a Sierra wireless website and does not work. I have installed the drivers, have an unlock code, but I...
- Jul 06, 2017
Hello marilyn579
This article may help you.
https://kb.netgear.com/25909/MEP-Unlock-AirCard-753S
DarrenM
ArodiD
Mar 22, 2017NETGEAR Expert
Hi Gillian,
If you have been supplied the unlock code, then all you need to do is insert another carrier SIM into your 763S. Once you boot it up, you will need to access the WebUI which will prompt you for the MEP code. All you need to do is enter the MEP code to unlock. Once it has been unlocked you will then need to go into the APN profile settings and ensure the correct APN profile has been selected as default/active connection. Please note: If you factory reset your 763S you will once again need to enter your unlock code.
Kind Regards,
Arodi
marilyn579
Jul 04, 2017Initiate
Help!! I have a aircard763s from Rogers. Trying to unlock it. I have a unlock code (pd $50.00 for it), but the instructions are useless. What is a WebUI?? Please help Grandma.
- DarrenMJul 06, 2017Sr. NETGEAR Moderator
Hello marilyn579
DarrenM
- marilyn579Jul 06, 2017Initiate
Thanks. I got it unlocked.
