ordos18
May 13, 2018Tutor
AirCard 785S without battery
Hello!
I have a problem with turning on AC 785S without battery, only on AC power supply. I found similar topic where someone confirmed that it is working, but not in my device.
When I connect USB plug to the router, NETGEAR logo shows up for a few seconds and then it turns of, it repeats on and on. How could I boot the device in this way?
FW Version: NTG9X25A_02.14.04.13
Bootloader Version: NTG9X25A_02.14.04.13
Hardware Version: 1.0
Thank you!
Maciek
- ordos18Tutor
ArodiD, thank you for your tip. I did try with 2,4A power supply, but with the same result. Maybe there is some current limiting because of USB autocoding, I will check it on another charger.
However, if 1A charger is sufficient for charging battery and running the network, it should work as well without charging the battery. Do you think that router needs more power during booting?
Thank you,
Maciek
