HenrikDK
Sep 10, 2017Follower
Aircard 790 freeze
Hi
please help me. My aircard freeze during startup amd never come further that the purple startup screen.
Nothing help. Only thing to do to turn off is to pull out the battery, but it continue to stop at the startup screen.
Help is appreciated
Thanks Henrik
Help is appreciated
Thanks Henrik
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello HenrickDK
If you have tried a factory reset and it does not work I would suggest taking it back to where you bought it. Or contacting Netgear support.
DarrenM
