danyelerm10
Nov 25, 2015Aspirant
AirCard ac785-100eus problem for xbox one nat open
hello i have a problem between my Xbox console and one modem netgear aircard ac785-100eus
which is the exact procedure for the nat open on my console?
the operation that I made are these:
I set a static IP in my console
in the modem I opened the various ports for xbox live (3070-88-80- etc etc ) associated IP address of the console
upnp active
nat the console is open, but if you restart the console becomes nat moderate.
where am I wrong ??
sorry for my English
thank you
- FenderBender711AspirantUnless you have a public IP, you will never get better than moderate. Feel lucky you can even get moderate. I have a Wii U and have been completely unable to get past sect, but have no problem with a device from another manufacturer.
I am with Verizon. - danyelerm10Aspirantdoes anyone know how to solve the problem? Thanks
- DarrenMSr. NETGEAR Moderator
Hello Danyelerm10
When you reboot the xbox is it changing ip address that could be the issue. The ac785 does not have a address reservation feature so check to see if its jumping IP address.
DarrenM
- danyelerm10AspirantOk thanks ..
