bigdickau
Feb 02, 2014Follower
aircard hub and aircard 760S
Hi All
i done a search on this site for some help about the aircard hub and aircard 760S.
no luck.
so here we go
i have a server with windows server 2008 R2 and running xampp. I have a bigpond 760S sitting in the aircard hub and connect to the server via rg45 network card. The network ip has been set to 192.168.2.200 for the server the hub has a gateway of 192.168.2.1. standard for this type of router. i have a public ip that is static. Now come the interesting part i can not see the server on the network but can find the router from the public ip.and the gateway ip. what am i doing wrong. the server is a hp ml350g5.
I am in sydney Australia
HELP!!!!
many thanks
Richard C
1 Reply
- apac_seApprenticeHi Richard, best way to do this is to setup the DMZ on the AirCard 760S to point to 192.168.2.2 then setup a NAT rule for the server IP on the AirCard Hub. You could also just place the server IP in DMZ of the hub but this may not be secure. You can use the guide in the following link for reference: https://dl.dropboxusercontent.com/u/53852158/OpenVPN%20Server%20setup%20with%20AirCard%20760S%20and%20AirCard%20Hub%20solution.pdf
