GeorgiePorgie
Jul 27, 2017Aspirant
AirCard Watcher App Taskbar Pop-ups
Hi Folks,
Two simple issues I hope you can help me with, the first being unbelievably frustrating trying to contact Netgear support by email. I've got an AirCard 309 with a 15 digit Serial Number and the support site only recognises a 13 digit number so I can't complete the registration details in order to get to their email page. I've tried without the first 2 digits and without the last to digits to conform with the 13 number requirement but to no avail.
The second issue is the reason for wanting to contact the support people in the first place. The AirCard Watcher app works fine apart from a big pop-up which appears about every minute or so above the taskbar in the right corner. You can close it but it reappears constantly and there seems to be no way to disable it withing the software settings. This is also not covered in the online help, nor the software options, nor in the user guide downloadable on the netgear support pages so I'm at my wits end.
Thanks in advance.
George
- DarrenMSr. NETGEAR Moderator
Hello GeorgiePorgie
Have you tried to reinstall the aircard watcher app? also pm me the serial number and I will try and figure out why you can not register it.
DarrenM
- GeorgiePorgieAspirant
DarrenM wrote:Hello GeorgiePorgie
DarrenM
Hi Darren,
Yes, I've uninstalled the Watcher App multiple times and rebooted the pc after each uninstall before installing again without change :-(
The serial number is 355389030502387. Please ignore the Model number given in the Model line of this thread as it autochooses from the limited dropdown list and won't allow corrections. The actual Model is AirCard 309 and it has DNA on the front of the gadget.
Thanks for your help and have a great weekend.
George
