SharonWillis's avatar
SharonWillis
Initiate
Mar 24, 2022
Battery low nighthawk m2
I forgot to charge my new Nighthawk M2 mobile router and The battery is extremely low and modem not working. I have taken the battery out and back in and it comes on for a minute then off again. It then starts charging showing the battery at 1% but has been at 1% for ages. Any ideas.
Thank you
  • plemans's avatar
    Mar 24, 2022
    Glad its charging!
    You might mark its solved so others aren't trying to fix it when you've got it working 🙂
  • plemans's avatar
    have you tried charging it with the router off?
    Or tried a different charger? Maybe the one you're using isn't supplying enough power to charge it from zero and run it at the same time
    • SharonWillis's avatar
      SharonWillis
      Initiate
      Thank you for replying.  It has finally moved off of 1%, now slowly charging, now on 7%.  Must make sure I keep it charged.
      • plemans's avatar
        Glad its charging!
