JTMNevejans
Oct 02, 2018Follower
C7100V goes down once a week
Just to preface, I try to be tech savvy but have no experience with networking. Assume I have no base knowledge and explain like I'm five.
I have a Netgear C7100V modem/router running firmware V2.01.33, not sure if its up to date.
I just moved into my brother's house and needed internet in my bedroom. Instead of running an ethernet cable thru the attic I moved the modem to my room and purchased a Nighthawk X6S wifi extender to get wifi thru the rest of the house.
Now, once a week the internet goes down. Not just the wifi, my ethernet connection doesn't work either. I am even unable to connect to the Netgear Genie. Every time I try to reboot it by unplugging the cord it comes back on with a steady red light on the modem (I think I saw that it's due to interrupted firmware update but I could be wrong). After the red light comes on I have to do a 30-30-30 reset, connect to Netgear Genie, reset the password, then the internet magically works.
This problem only started since I moved the modem and added an extender.
Since it seems to happen every Tuesday I thought maybe my ISP was changing my IP address and the modem wasn't keeping up. I just don't understand why it would happen now or what I could do to check my theory. It also seemed weird to me that I couldn't connect to the Netgear Genie. I don't know what it means but it seems important.
Like I said, I have no knowledge of modems so please explain everything very simply.
-Jordan
1 Reply
- ComcastCowboyAspirant
My C7100V has been going off network several times a week since June 28 and have tried countless solutions - drop amp, splitter removal, etc - nothing worked. Even had the red power light adventure which prompted Netgear to replace it. After this morning's failure, I was on my way to the Xfinity store to rent an XB6 when I noticed the firmware updated to 2.01.37 - Hoping this solves the problem.
