fromtimestamp's avatar
Mar 20, 2023
Can MR6450 be connected to 5G SA?
Can MR6450 be connected to 5G SA? I'm in China. I bought Mr5200 before. I couldn't get the SA update for a long time, so I had to give up this machine. By the way, has Mr5200 supported 5G SA so far?
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    MR6450 supports SA. The following band are enabled for SA.
    No plan to enabled SA on MR5200.
    Thanks
