Marian_P's avatar
Sep 26, 2025
Carrier aggregation info on MR6150?
Does M6 5g support carrier aggregation? I guess it is. If so, how many carrier aggregation bands can I use? For example, the Nokia 5G Receiver 5G16-A supports 4 Carrier Aggregation (4CA), allowing it to achieve up to 300 MHz of aggregated bandwidth.
Any help will be much appreciated!
Oh, I also want to know if there are any recommended 5G antennas for M6.
Thanks.
