Quigly
Mar 22, 2018Follower
Compatibility with Cable systems
I just purchased a new CM700 cable modem. I am thinking about switching my internet provider. I need to know if the CM700 cable modem is compatible with the Century Link fiber optic system. Thanks for any help that can be provided.
Quigly
1 Reply
- JasonNNETGEAR Employee Retired
Hi Quigly,
It should be compatible but you would have to confirm with your ISP
Below are the links to the Specs Data Sheet & User Manual for the CM700:
Data Sheet:
https://www.netgear.com/images/datasheet/cable/CM700.pdf
User Manual:
http://www.downloads.netgear.com/files/GDC/CM700/CM700_All_MSOs_UM_EN.pdf
Please let me know if you need anything else. :]
- Jason N
