Granny888
Mar 25, 2022Tutor
DATA USAGE INFO UNAVAILABLE AT THIS TIME.
Hi. I'm sorry if this question has been asked already. I need to watch my usage as I do not want to go past the Telstra allowance that I have paid for. For the past 2 1/2 days I have the above message re my data. I have checked and the latest update is already on the router. Can anyone help please? thank you.
- Retired_Member
Hi Granny888
This message on devices and their webpage has been a regular feature from Telstra.
After a prolonged outage in 2018, I have noticed it as an ongoing recurrence mostly for a few hours overnight for years.
Telstra performed a "planned upgrade to our internal systems" around 25 March, which was severe enough to drop pre-paid accounts from the MyTelstra App and the Account Web Page. They are now back.
Unfortunately my device is still showing the 'Data usage info unavailable at this time" for a continuous period despite reboots. I personally will wait a fortnight before I go down the rabbit-hole of asking for Telstra Support.
Have you got a Telstra ID? If so you can sign in at https://www.telstra.com.au/ top right hand corner, which also gives you the option to create a Telstra ID.
With an ID, you can also use the MyTelstra app on a smartphone. The usage data is available for post-paid and pre-paid services.
It is a workaround but it may shed a little light.
Hi. Thankyou for your response. It was helpful. I would appreciate knowing what your response is from Telstra when you go there. Which I am sure you will! đ I have had my visit to Telstra !!!
- Retired_Member
Hi Granny888
From the !!! am I to assume the outcome was less than satisfactory?
Being 200km from the nearest Telstra Shop can be a blessing in disguiseđ
The fortnight was up so I used messaging in the app to ask for tech support. Telstra have added the ability to upload screenshots, which made it a lot easier to detail the issue.
I was able to upload the issue and receive an incident number for an âescalation to the network team for investigation.â With a promise of contact when the network technician has done the investigation.
In the mean time for my own troubleshooting I have tested the sim in another device - AC790S which had been working fine last time I took it for a spin. It too has the same data information unavailable message. Took photos and made screenshots just in case the âescalationâ peters out.
Telstra MR1100
â
Telstra AC790S
â
If I have not heard from them in a week or so I will try again. Since Telstra removed CrowdSupport and as I am social-media averse, getting help can be an exerciseâŠ..
