Visserd
Aug 21, 2019Aspirant
DC112A firmware update fails
I tried to update firmware on my Dc112A. It says there is a new update available. When I select to update it gets to the stage where it is updating language file and fails. I have tried resetting modem and tried several times with no success. I also tried to look for the new firmware files but i can't find them in the download centre
- KadlinAspirantI have a similar problem upgrading from Current GUI Language Version: 1.0.0.42_2.1.38.3 New GUI Language Version: 1.0.0.44_2.1.38.3 Current Firmware Version 1.0.0.42 New Firmware Version 1.0.0.44_1.0.60 I get the error Failed to update GUI language file. Help would be appreciated.
- Blanca_ONETGEAR Employee Retired
Hi, All,
We are investigating on this. We will get back to you for any updates.
Blanca
Community Team I have exactly the same issue.
- Ender76Initiate
I too am having this issue and have been for several months. Fails to install the language file from the new firmware 1.0.0.44_1.0.60 via auto update. I am unable to do a manual update as the Firmware for these smart cradles are nowhere to be found for download.
Hi, All,
This has been brought up already to engineers. I will get back to you guys for any updates.
Blanca
Community Team- Blanca_ONETGEAR Employee Retired
Hi, All,
Please try again the firmware update and let us know of the result. This should be fixed by now.
Blanca
Community Team
- yoyojpgTutor
Bonjour,
Moi aussi j'ai le même problème. Merci de répondre au plus vite s'il vous plaît
J'ai essayé de mettre à jour le firmware de mon Dc112A. (ancien firmware : V1.0.0.34_1.0.60 et le nouveau : 1.0.0.44_1.0.60)
Il indique qu'une nouvelle mise à jour est disponible. Lorsque je choisis de mettre à jour, il arrive au stade où il met à jour le fichier de langue et échoue. J'ai essayé de réinitialiser le modem et essayé plusieurs fois sans succès. J'ai également essayé de rechercher les nouveaux fichiers du firmware mais je ne les ai pas trouvés dans le centre de téléchargement
Allez voir l'image en pièces jointes
Hello,
Me too I have the same problem. Please answer as soon as possible
I tried to update the firmware of my Dc112A. (old firmwar : V1.0.0.34_1.0.60 and the new : 1.0.0.44_1.0.60)
It indicates that a new update is available. When I choose to update, it comes to the stage where it updates the language file and fails. I tried to reset the modem and tried several times without success. I also tried to search for the new firmware files but I did not find them in the download center)
see the attached image
email : [email protected]
Thanks
- UC74GuideI have the same problem. Please answer as soon as possible
I tried with genie sw (for window pc): it failed too.
Can you give us a link to the firmware file please?- UC74Guide
- UC74Guide
- caribicaAspirant
nothing works same issue here, what is the fix or workaround, can somebody upload a manual firmware update?
- caribicaAspirant
Hello, stil same issue, my SKU is: DC112A-100NAS
any fix?
