Shannon333's avatar
Mar 13, 2020
DC112A Firmware Update fails
Hi,
My DC112A has a firmware update available (V1.0.0.44_1.0.60)
I'm currently running V1.0.0.42_1.0.60.
Hardware VersionDC112A  V1.0
Firmware VersionV1.0.0.42_1.0.60
GUI Language Version
V1.0.0.42_2.1.38.3
It displayes the "Firmware is Available" Banner yet when I try to auto update it fails because "No firmware is available"
When I download the firmware from the site and try to manually update I get:
"This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product."
I had this same issue with the version prior to 1.0.0.42.
  • My SKU is DC112A-1TLAUS
    there is a previous thead about this marked solved from last year but this issue still exists for this SKU
    • Shannon333's avatar
      Shannon333
      Star
      I really want to get this sorted due to it being vulnrable.
      Security Advisory for KCodes NetUSB Unauthenticated Remote Kernel Vulnerabilities on Some Routers, Gateways, Extenders, and Smart Cradles, PSV-2019-0029
      Associated CVE IDs: CVE-2019-5016; CVE-2019-5017
  • I have exactly the same problem. Download the correct formware, device says update availabe and yet cannot find automatically. Try the manul aupdate method and I am told the file is incorrect. The file suffix is .chk.
      Shannon333
      Star
      Seems netgear doesn't care.
      We are now up to 1.0.0.46 Hotfix and the SKU still isn't supported
      • Qwackers's avatar
        Qwackers
        Initiate
        Ditto Shannon333 comments - seems Netgear does not care about the Australian SKU of the DC112A - Netgear have released a number of releases where the AU model isn't supported currently stuck on Firmware Version V1.0.0.42_1.0.60.  I'd love to see a resolution to this and move to close the known security flaws patched in Firmware Version 1.0.0.48.
