WindyWilson
Mar 31, 2020Follower
Error message on my Nighthawk2
Hi ... hope you can help?
I have the following error meesage on my Nighthawk 2 -
Webkit encountered an internal error.
Not sure what it means or what I need to do but I am unble to access any of the function for the modem.
Any advice would be appreciated.
Thanks
If this is the MR2100, you might get better and quicker replies, and find other answers, over in the appropriate section for your device:
Cable Modems & Routers
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message.> over in the appropriate section for your device:
> Cable Modems & RoutersThis must be some new meaning for "appropriate". I'd try:
https://community.netgear.com/t5/x/bd-p/aircard
Perhaps that moderator will have a better idea about the appropriate
placement of this discussion.- JohnPengNETGEAR Expert
So factory reset can't fix the issue?
Please advise your device SKU, MR2100-xxxxxx.
Thanks
