netcommuner
Apr 23, 2018Aspirant
Factory Reset not accepting 'Password'
hard reset modem, 3x.with paperclip i pinhole in back... but still wont accept the system pw provided on label on modem device
appreciate any tips asap tx
- 80njc80Luminary
Try 'password'. Case sensitive.
- JasonNNETGEAR Employee Retired
Hi netcommuner,
Did you issue with the password get resolved?
Please let us know. :]
- Jason N
- netcommunerAspirant
yes thanks, finally after 3x tries it took the 'system pw' provided on the side of the modem
JasonN wrote:
Hi netcommuner,
yet tx, put in the 'system pw' on the side of the modem - after i disconnected modem from power, and coax for 3 hrs, and it processed it, tx for all the help
- Jason N
- matador86Aspirant
After full factory reset, my {verified correct} google password will not work.I verified several times I am entering it correctly.
