Djonee
Jul 29, 2020Aspirant
Find so Hard to belive that there is not solution
I Find so Hard to belive that there is not solution for a relooping Nighthawk MR1100 on boot but to send it to the company for a replacement, wich is a good thing dont get me wrong but for people like me that bought the device in ebay and paid not small money for it, is something terrible, such an amazing device and all of the sudden you get to your home and the thing is on a loop because a gone bad update, update that you did not athorized, and there it is a worthless bricked piece of engeneering sitting on a desk, there has to be a solution for it, has somebody fix one? I have not read a single story of a succesfull reflashing
- icarusponyLuminary
1. Download AC78x Netgear drivers version 4.3.00 and install them on PC. Also, download FDT.EXE version 4.6.2.0.
2. Download MR1100 firmware (12.06.11.00 or 12.05.05.00). Put it in the same folder as FDT.EXE. Hopefully you have the generic US version of the MR1100 and not an AT&T branded version as using these firmwares on an AT&T MR1100 will permanently disable features like LAA.
3. Download and install Putty or just enable telnet in Windows (Turn Windows Features On or Off > Telnet Client).
4. Disconnect PC from Wifi and Ethernet. Your computer should have no internet connections.
5. Remove the SIM card and ethernet cable from the MR1100.
6. Factory reset the MR1100.
7. Connect the MR1100 to the PC via USB.
8. Try to connect to the MR1100 via Putty or Telnet. The IP is 192.168.1.1 with port 5510. If using telnet, the command is telnet 192.168.1.1 5510
9. Once connection is established, you may have to act quickly to halt the boot. The command is AT!BOOTHOLD
10. Open a command prompt and browse to the folder with FDT.EXE and the .SPK firmware file. Type the command fdt {firmwarefilename}.secc.spk
11. Let it do its thing. Even if there is an error that says the upgrade failed, wait 15 minutes. Eventually, it will reboot itself.
- DjoneeAspirant
Hey , thnx for responding , that was the first method I tried but like I wrote in the post the mr1100 is looping I cant restore it to factory is unresponsive , not to every button on it but to everything, I cant make it comunicate with the pc by putty or FDT, when you say connect by USB , you mean c-type connector or the other USB male-to-male cable? belive me I've tried many times with no success
The USB connection is C-type (on the MR1100) to your PC (A type).
This opens a connection that is different than Wifi or ethernet.
Are you factory resetting the device with the paperclip button under the SD card slot?
How many seconds does it take to cycle from one reboot to the next?
