robatl's avatar
robatl
Star
Sep 06, 2021
Gig ports speed reduced when access control is enabled.
Nighthawk LAX20  Firmware Version V1.1.6.28_2.0.49
Anyone else experiencing this issue or is my router defective?
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi robatl
    Welcome to NETGEAR Community!
    Please provide the speedtest results when Access control is enabled and disabled.
    Have you tried factory resetting the device?
    Blanca
    Community Team
      • Blanca_O's avatar
        Blanca_O
        Hi robatl
        May we please know the speedtest result when access control is enabled and disabled.
        Blanca
        Community Team
  • I may have found the issue... I disabled the WMM feature under QOS and my speed on the gig ports normalized. I am getting my speeds with access control enabled.
    • Blanca_O's avatar
      Blanca_O
      Hi robatl
      Thank you for update. We'll share this information to the product team.
      Blanca
      Community Team
      • robatl's avatar
        robatl
        Star
        I conducted a failover test to cell, since then my speed on the gig port has been back in the 300mbs to 400mbs. There are several scenarios that cause problems with the gig ports. I have rebooted and powered off the device several times. The speed gig speed would appear to working then it falls off.
