Boo1's avatar
Boo1
Follower
Apr 20, 2019
Interent Connection
Have 5GHz but also need to be able to choose 2.4GHz - how can I add the 2.4GHz option?
  • schumaku's avatar
    schumaku
    What hardware model, what firmware are you talking about here?
    Newer models make use of one SSID for both the 2.4 and the 5 GHz band, so it's up to the client to decide on the better signal.
  • It should be in your routers WiFi configuration settings if it exists.
    You may need to enable 2.4 and choose a seperate SSID than the 5G....
