iroody
Jun 19, 2017Aspirant
LB1110 bridge mode with unifi USG
Hi,
I am trying to setup a unifi USG behind my LB1110 modem. When I set the modem to bridge mode, the USG has no internet access and when I set the modem to router mode, I get a double NAT.
Anyone can recommend a solution?
Thank you.
- netwrksMaster
Did you reboot the modem after changing to bridge mode? Reboot modem, wait until the modem comes back online.
Power up your USG and follow the setup: https://dl.ubnt.com/guides/UniFi/USG_QSG.pdf - The assumption is you have a Unifi Controller. Don't use the same subnet that is on the LB1110 on the USG..
- iroodyAspirant
Thank you for your answer, yes I did reboot the modem.
LB1110 is using; ip 192.168.5.1 and Netmask : 255.255.255.128
USG is using 192.168.99.1 and Netmask 255.255.255.0
I am using the newest version of Unifi controller and the setup is as described in the PDF.
- netwrksMaster
Found this llink on the UBNT site. Not clear if it's a USG or LB issue. You may have to dig further on the UBNT site.
