LivingwithIT's avatar
LivingwithIT
LB2120 4G modem AT&T / TMobile - SIM Card questions.
Trying to determine the best plan to use with the LB2120:
a) Prepaid xGB Data plan SIM card
b) Prepaid Unlimited Voice/Txt/Data plan SIM card
I looked at both AT&T and TMobile
Option a) seems to be more expensive at the carriers.
But I see cheaper pricing for b) however, I'm not completely certain this will work.
Can someone confirm that it is possible to use a "phone" SIM for the LB2120 and/or share experiences with using and setting up the service?
What do I need to communicate to the carrier.
Thanks;
  • The Phone SIM should work with the device as long as it would have a data subscription. - Rhys
  • RVALENZ's avatar
    RVALENZ
    NETGEAR Employee Retired
    • LivingwithIT's avatar
      LivingwithIT
      Already got T-Mobile’s unlimited $40 plan. Thanks for the reply anyway.
