caprock's avatar
caprock
Tutor
Jul 03, 2019
LB2120 4G Modem on Visible prepaid cellular
Have been using this modem with T-Mobile for several months and it works great!
I just purchased the budget Android phone, the Visible R2, and activated this new phone from Visible, a Verizon prepaid plan. After success working as a phone, I tried a simple SIM swap and can't seem to get it working.
Unit LedS
With the Visible SIM: the Power led is on, but all other leds are off, suggesting an 'Unknown Error'.
Using the the IME1 app results: Model: Voyage 4; Brand: ZTE; IME1: TAC:990010 FAC:38 SNR:003205 CD:3
Has anyone else had success with this Visible plan? Any clues would be welcome!
Thanks
  • Hi caprock ,
    Please check APN profile settings as it may not have automatically setup the APN profile for your new ISP SIM.  You can manually set it up via the WebUI and re-check connection.
    Arodi
    Community Team
  • Visible by Verizon -
    This appears to be an artifact of PREPAID plans.In my case the modem displayed the LED pattern for NO SIM. Looking into the modem at 192.168.5.1 for ABOUT, I could see that the modem had acquired the SIM card details yet could not complete the connection as viewed by the Network Status without an IP address.
    After much examination, I determined that the LB1120/LB2120 does not support this connection, most likely due to this account type.
    • ArodiD's avatar
      ArodiD
      NETGEAR Expert
      Hi caprock ,
      Arodi
      Community Team
      • caprock's avatar
        caprock
        Tutor
        ArodiD, thanks for this. In my situation I have three accounts, with the T-Mobile as my primary: APN fast.t-mobile.com, IPV4, IPV4. This is my working device profile.
        I have tried two other device accounts: Verizon (post paid) and Visible (prepaid Verizon). The Verizon account works and Visible does not.  In both cases, the ABOUT and APN are the same:  APN Name: Verizon (vzwinternet); APN: vzwinternet; Authintication: None; PDP: IPV4; PDP Roaming: IPV4.
        Drats, this was a good idea to check. I had posted this but apparently not succesfull.
        Thanks for this heads-up!
  • These Modems seem to have been ban from Visible's service, anyone else having issues or know how to get around this?
    We've been using them for a week with no issues until yesterday morning.
    In one area, the modem connects, until a device is plugged in, then it disconnects and retries and retries and retries... in another area, the modem attemps to connect then retries and retries and retries without a device plugged in... tried in router mode and bridge mode.
    I have a LB1121 and two friends have the LB1120... pop the SIM back in a phone, and the phone works with tethering, even bridging the wireless signal to the WAN port of a router to split it works... but i'm attempting to put the modem up in a tree with two large yagi antennas, so tethering with a phone is not an option for me.
    • caprock's avatar
      caprock
      Tutor
      That is my impression but not confirmed yet. Mine worked for a few days, dead yesterday. Took the Sim back to a phone and works. Also tried hotspot and that was ok. Actually using a hotspot now w/o issues. My thought was that an automatic tool is looking for Visible with downlink IPs. I'm using TMO also but Visible has the more consistent signal.
      • caprock's avatar
        caprock
        Tutor
        Well seems to be bad news for those trying to connect a router to the Visible cell service for use with the Netgear LB2120 4G Modem.
        After a more careful examination of the Terms of Service there is a detailed restriction that probably applies in the (e) argument (attached).
        In the Features there is only a short description for hotspot support: "You'll be able to connect one phone at a time."
        I was hoping to power my home with the 5mb Visible service, but this restriction does seem to be a real - and enforced - restriction. This does not appear to be an issue with TMO, but costs $75-$85 and has a weak signal. [I am in a rural environment where the only alternatives are U-Verse (1.5mb/256k) or a local radio link ($60+ for 3mb/1mb) - no cable tv/internet is available]
        BTW: T-Mobile is currently beta-testing a whole-home 4G cell service at this time, but is available with a TMO invitation onlly.
